What to use to fill a trench
11 Aug 2006
Hi Guys,
I've just had some heating pipes put into the concrete floor, I dug the trench out and its around 50mm deep, 60mm wide and 5m long.
What mix should i now use to fill the trench and cover the pipes?
Many thanks
Rob
Rob - copper or plastic pipes? Insulation? Pipe-wrapping? What type of floor covering is going on top? Note that your local Water Regs might state that pipes installed within solid floors should be able to be withdrawn & replaced.
Ceramic tiles or timber floor - 60mm wide trench I'd go with builders foam. Advise re other floor finishes.
