what type of plasterboard do i need to use behind my fire
13 Feb 2011
hi i am putting in a solid fuel fire, what plaster board can i use around the fire, the sides clear by 300mm the back is undecided, i need to know the needed thickness of the firewall behind the stove if closer then 150mm
I wouldn't be using plasterboard that close. If you have to board I personally would use Supalux or your other option is to wet plaster on a masonry background.
