Which Wacker Plate or Compactor Plate to buy?
17 Jul 2013
Buckinghamshire
Hi guys,
I am trying to buy good compactor plate or wacker plate but there are so many different types on the market.
I need wacker plate to compact MOT 1, then I want to wacked the block paving and I do not understand do I have to have rubber mat or not and what is the optimum power of engine or vibrating for wacker plate.
Please help I do not want to spend fortune but also do not want to buy something it will "die" after two weeks.
I will use moderate for some other projects as well.
I was checking on eBay and online and it is mess out there...thousands if not..
Thank you in advance for any advice.
8 Jan 2005
Bath
Hire one till you know what you're doing and can afford to buy a decent one.
That way you get to try the good from the bad.
15 Jul 2013
West Midlands
I've a similar question, though to do with hiring, so i guess we'll need the same spec irrespective of where it comes from.
I need to wacker some mot type 1 down ready for concrete pad to be poured, so the options are:
Light Vibrating Plates: Ideal for use in awkward and narrow areas, whether you are compacting sand and gravel or bedding-in paving.
Light Compact: Ideal for DIY applications
Light Professional: Robust for heavy contractor use
Medium Vibrating Plates: To compact hardcore, sand or gravel you need large, medium-duty vibrating plates like these powerful, easy to use models.
Hauc Model: Vibrating plates incorporate a stepped base to meet regulations. Safety goggles, ear defenders, gloves and safety kit can be purchased online or when you collect.
Which one do we go for?
