whirlpool dishwasher 6830, wont run
1 Oct 2006
Shropshire
when swithced on the Start button flashes twice constantly, but will not start the programme(set to Normal)The display that normaly shows the Time Remaing is not lit at all. Any idaes anyone :cry:
F2 indicates a flooded base. Tip the machine back about 45 degrees and see if any water drains from the base. (Put towels down just in case).
Reset the pcb by pressing and holding the start button, select a program and try again. If f2 is indicated again it's likely that it is leaking into the base.
