whirlpool dishwasher g2pdwi shorting
31 Dec 2009
Our whirlpool g2pdwi tripped the fuse in our main fuse box and does so instantly every time I switch it on. It makes quiet clicking noise first. Any advice would be hugely appreciated.
Sounds like an earth fault. If you don't know anyone with an electrical background to help track down the problem then you should consider calling qualified assistance. DIY on faulty electrical appliances can cost you dearly :shock:
Many thanks for your help zipper. Not sure what an earth fault might be, but any further info anyone might be able to piont me in the direction of, I'd be grateful.
Other helpful souls may kick in here & perhaps suggest another approach to the problem. But anything beyond trying the machine in another socket I would be inclined to advise you to contact a qualified service engineer to identify & repair the problem correctly. I know it is expensive, but it's better to spend a little money than risk the alternative...
We tried the machine in another socket and it tripped the fuse again after a minute or so - does that confirm your assessment?
check the heater or circulation pump for starters.you will need a meter to check .
Thanks for this rocks, but my missus just summed it up nicely, "It's above and beyond what you can do." I can wire a plug - that's about it.
There is obviously nothing wrong with your house electrics, the problem is definitely the machine. If this isn't your particular area of expertise I would advise you to call qualified assistance. Better to do that than risk injury or worse. Sorry I couldn't help more.
Really appreciate your input - at least I know who I need to call.
Nik
