Whirlpool Ikea DWF B10 Dishwasher
27 Jan 2012
West Glamorgan
When I set the dishwasher it sounds like it's going to start but it stops and there is a clicking sound from the control panel at the top of the door. Any help much appreciated!!!
Water on the baseplate.
Turn it off & tilt the machine forwards (have some old towels ready & expect water to run out).
You should be able to restart a program but if it happens again fairly soon you need to track down the source of the leak.
Thanks Zipper - you were right. The base plate was wet and that had activated the auto cut out. I tilted it forward - water came out as you had warned. I removed the base plate but at first couldn't see and leak - but then saw that the outlet hose had a split in it. Took it to a small supplier and got a similar one for £6.50. THANK YOU!
