Hiya.. I think the answer to this is "the DNO" but a bit more info would be great
I've bought a property that has a 3 phase 4 wire supply
I can see the 4 wires(plus earth) coming out of the ground and into the bottom of a large economy 7 meter
The fuses have been pulled on the 3 phases supply and are on the floor in front of the meter. The panel under the meter where the wires go in has an intact security tag..
Judging by the way there's an unpainted rectangle on the wall next to the meter, there was once an isolator of some sort there. the wires from the CU reach down to the rectangle. I'm assuming that the supply was disabled by removing the tails and isolator, and then sealing the meter terminals back up
In going about getting this reconnected, who should I call? A sparky, electricity northwest, or eon/npower/supplier? Who buys the isolator? who buys the tail wiring? I'm wondering, you see, should I buy an isolator and 25mm tails, have a sparky mate fit it and leave the tails with enough length, and then right someone else up to have them connected to the meter and the fuses reinstalled and tagged?
Thanks guys
Thanks guys
