Have now spent a few days trying to get my potterton80 to work on CH.
DHW seems to work ok, but can be a little slow.
Had a problem with boiler locking out after using DHW but cleaned the flow switch assembaly and now the boiler recognises when HW is not being demanded.
When the boiler fires up in CH mode on constant the burner goes for a bit then cuts out. It doesn't go into lockout mode. The boiler will then relight after 2/3 mins. It repeats this but the burner never really goes for more than a minute.
The pump appears to be spinning (by checking Hex nut in middle).
I have already replaced the complete diverter valve assembely.
I have removed and checked over the heat exchange and water seems to flow freely through it.
I have also isolated the boiler from the pipework around the house and checked this seperately using a hose. Water flows freely all round the radiator loops and any water coming out is generaly clean looking.
Does anyone know of any other checks I should make or what this problem could possibly be????
Getting v cold.....
Getting v cold.....
