Follow along with the video below to see how to install our site as a web app on your home screen.
Note: This feature may not be available in some browsers.
Looking for a smarter way to manage your heating this winter? We’ve been testing the new Aqara Radiator Thermostat W600 to see how quiet, accurate and easy it is to use around the home. Click here read our review.
just brought a new sony laptop. i have the choice to have 32 or 64bit win 7 on. which would you choose? i use it for internet surfing etc. is 64 bit better in the longrun?
thanks
I'd go for 64bit. 64bit will run 32bit programs, and as mentioned means for the operating system at least you'll get more out of the hardware. Not only that but at present there are very few 64bit viruses and I believe no 64bit rootkits. Though that doesn't mean 32bit viruses wont run. So technically its more secure.
I wouldn't say they are fazing 32bit out as such as many programs are still 32bit with no intention of changing just check out your x86 program folder! but it is the future.
What memory do you have installed currently?
What is the maximum your motherboard can support?
If you're working with large files or running applications that consume a great deal of memory,
then 64-bit Windows will typically give you a slight performance advantage over 32-bit Windows running on identical hardware.
64-bit Windows 7 supports more physical RAM than 32-bit Windows 7 (192GB on non-Home versions vs. 4GB for any 32-bit flavour).
So 64-bit is the way to go - however, as you already have the laptop I'll assume it comes with 2-4GB of memory?
Probably means you will have to fork out money to expand the system memory on a brand new machine for a slight perfomance difference for surfing.
I'd suggest you also look at all the programs and hardware you are using / going to use. Some of the older stuff does not work with 64, so it costs more to use in the short/medium term..
