Wireless printer question
7 Sep 2008
Kent
Canon TS8571 wireless printer. This is placed within a few feet of the BT Hub2. When I first switch on it doesn't connect and won't until I do the following (suggested by an IT tech from work). I go to services. msc, turn off the print spooler service, turn it back on again and exit. Works every time, so do I have to live with it or is there a solution?
Wireless home printers are notorious for poor handling of DHCP. Once it's connected and running, go into your BT Hub admin settings and tick the box to ensure the printer is always given that same IP address when it logs in.
Turning the spooler on and off may well just be pinging the DHCP server in your router to refresh the IP it's given and thus starts working again. Setting your printer to a fixed/reserved IP will fix this. If you don't recognise the printer in the list of attached devices, look for the MAC address on the printer somewhere then you can look for that same address in the connected device list on your router.
