Hi all,
New to this forum.
I have recently moved in to our first house so getting in to DIY. My first project was to get the Nest Gen 3 Thermostat set up and working.
This is the exact wiring of my PCB Board:
Full manual here: https://www.vaillant.co.uk/downloads/ecotec-installation-and-servicing-manual-261417.pdf
So here's what I've done so far:
Taken the L&N from X1 above. Powers the heat link fine.
I have tried the Heat Link connected to:
X100 Blue - gives me Nest working perfectly but NO hot water
X100 White - gives me hot water but NO nest
X100 Pink - gives me hot water but random, erratic heating (not following nest at all)
What have I done wrong?
The manual also mentions on page 30:
> If you connect a 230 V AC time and temperature control to the boiler, then remove the bridge at input 24 V = RT (X100 or X106) if a bridge exists.
> If you connect a weather compensator or room temperature control via eBUS, then bridge input 24 V = RT (X100 or X106) if no bridge exists.
> I If using low voltage (24 V) controls connect these in place of the bridge marked RT 24 V (X100 or X106).
The cable I have tried on X100 is connected to ports 2 and 3 on the nest, as per: https://nest.com/support/images/mis...Nest-Learning-Thermostat-Install-Guide-UK.pdf
I thought I was okay with this but apparently not!
What way should I have this wired up?
Any help is greatly appreciated!
(I have tried searching the forum but there doesn't seem to be a definitive answer for my type of boiler)
New to this forum.
