worcester 24 cdi burner going out after 30 seconds
27 May 2006
Hampshire
I have taken off the heat exchanger again and refitted it, I now have the hot water pressure back but the gas burner still goes out after about 20-30 seconds on both the HW and heating. It was fine before I replaced the exchanger.Is there anything I could try or should I call my Man???.
have you now got an air lock? Have you checked the pump for turning and the impellor for broken?
What was the problem with the DHW flow restriction?
Are you sure thre AAV is working properly?
Tony
All is working fine now, the vent at the top had stopped working and after several "vents" it stayed alight.
Thanks all
