Worcester 240 Combi flow switch ?
7 Nov 2003
Hi all,
I hope you can help, I have a Worcester 240 Combi boiler installed, it has worked great for a several years.
Yesterday, I was in the shower, and you can guess the rest, cold water shot through and I give the tiles a scare ! :shock:
Now it seems that 50% of the time the hot water demand will kick the heat in and other times it will not start it. Also, using the shower means I get hot water for about a minute before it starts to run cold.
From reading around the internet, it seems like a flow switch problem, can any one else concurr or otherwise? Is this something that a competent DIY person can do?
Many thanks
Peter. -
The flow switch on the 240 is activated from the diverter valve, if you lower the control panel by removing the two small screws at the far ends of the panel you will clearly see the brass diverter valve with its black plastic microswich head. At apeak time when the water pressure is low say 5 or 6 pm run the hot tap you should see the plunger come out smoothly and sit against the two micro switches and stay put, if it does not reach or bounces back or cant reach when the tap flow is down to 3 lt per min then you need a new diagphram which is a fairly easy job, just shut off water remove micro switch, undo one pipe connection and undo around 10 fixing screws, about 20 mins.
