Our 2 year old worcester 24i has been playing up for quite a few weeks now and we are cold! We have had two engineers out to look at it and a new PCB, thermistors, gas valve put in, but to no avail.
At first the fault was intermittent. The HW worked, and the CH would come on and then cut out within about an hour , only coming on again if we turned it off at the wall and then turned it back on. Gradually this got to be within 2 minutes and then it cut out, and we had to wait about an hour before it would come on again once turned back on at the wall. Now the HW isn't working either- the same thing happens. The flame lights for less than 2 minutes, and as soon as the hot water starts coming through, it cuts out and won't relight.
There is no variation in the cooker flame when the boiler is trying to light.
Once the engineers had replaced all the bits mentioned above, they now say it must be sludge in the radiators causing it. We have been unable to get the rads off to empty them, as they are stuck on tight so have a plumber coming this week to clean them out for us.
My question is any ideas what could be causing this problem? Is it likely to be the sludge or will the problem still persist?
Your ideas would be most welcome as it is cold here!!!!!
