hello all,
Hope you can help. As probably understood from the subject.
35 cdi Mk2 F1 fuse keeps blowing when the thermostat is turned up.
background is that the diverter valve as been recently changed and the front facia also replaced.
The bloke that changed it has gone on holiday now so a bit stuck.
I checked the connections for the therm first. I seeing there should be a link between the ST8 Ls and LR ?
the thermo is a Honeywell T6360b theres only 2 connections made from the 1 and 3 terminal.
Which terminals on the ST8 should be used and should there be a link?
Also if not the above prob..Can I unplug all the connections but the power and try to find the fault? go through a few fuses but wortha a shot?
Will the thermistor being faulty be the cause ?
any help much appreciated.
thanks in advance
thanks in advance
