Evening all...Bit long winded this, i'll be as brief as possible.
Recently installed 40CDi on an existing powerflushed open vented system, 28mm boiler F&R to pump & controls approx 6m from boiler. On demand boiler fires briefly (2-3secs) before displaying a hydraulic fault symbol (opposite corners flashing on and off with flow temp). This mode begins with the flow temp as low as 22deg and continues for approx 45mins at which point the boiler usually fires up properly...Worcs came out and ok'd the appliance and pointed the finger at the pump, we upgraded the pump from a 15/60 to a 25/55 and problem persists on all 3 pump speed settings. When boiler is in high fire all 25 rads kick in nicely and I am as sure as I can be that there is not a circulation problem.
No other error codes are being displayed and all I am getting from Worcs Tech is "...it's not a boiler fault..."
Any thoughts would be gratefully recieved, thanks in advance Mark.
