This has been in the house 6 years from new.
The problem is that sometimes it starts and stops as requested by the timer.Other times the boiler pumps runs on for hours(it should stop after about 15 minutes from shut down).Other times the boiler wont strike up when the timer asks it to.But you can activate it by turning the dial on the boiler to zero and then back up then it strikes up. The boiler has been regularly serviced and the stat changed 18 months ago when a similar problem occured.Everything possible has been checked out and we cant find anything wrong,it should work properly.Flu ok,pcb seems fine as far as we can tell.Water test proves no possible blockages. Its been servied and sorted by a reputable company.
Any ideas what else might be worth looking at. Could it be the stat could be faulty again.
