worcester heatslave9.24 pressure loss no hw or ch
11 Jan 2006
Edinburgh
hi im pretty new to all this but been having major problems.Moved into property and boiler in perfect order,noticed small leak couple weeks later and since then all downhill. at the moment i have no pressure and therefore nothing happening.we got a small screaming incidence with the boiler and since then nothing has worked bled all radiators incase it was something to do with that but to no avail.whenever i switch the boiler on it makes all the right clicking noises but just does nothing from then on, is this to do with the pressure if so how do i get the pressure back up.
thanks in advance,one freezing fem
I had a simular problem once, there should be a small tap somewhere on the pipes underneath your boiler, twist it till you see your pressure rise to it's recommended level ( normally indicated on the gauge) then turn the tap back to it's off position.
I hope that helps
