worcester i24 junior boiler
1 Aug 2012
i need help, my boiler broke down a month ago, all fault finding pointed to main pcb, replaced that and now if water is used to run bath or CH is used for a time, i get the 4 flashes per second fault, it seems to overheat but with cover off to test the overheat switch it refuses to go into fault, have tried turning gas pressure down in case this was causing the overheat, but is still same, if anyone knows what is causing this it would be much appreciated, or should i bite the bullet and go straight to getting a new boiler ?
lowered it on the gas valve in the boiler, its now at lowest setting recommended in the manual when on high fire
Nothing to do with gas- hope you know what your doing? Otherwise fga will be well out.
Most likely blocked low water pressure switch, or melted aps
aps works fine was tested when pcb went, an water pressure switch was replaced 6 months ago, and has also been tested all ok
