Hi new to the forum
I been on other diy forums and no seems to want to give advise I hope someone can help
I have a 12x8 shed/workshop at the bottom off my garden and I would like to run power to it I have a blangdon power safe in there at the moment but there is only some tools I can use.
The power tools i will be using is compressor and a welded both i been using on the blagdon set up as both have 13amp plugs and a 1kw heater they r not use all at the same time thou.
The shed is about 30ft max for my back door and 58ft to the cu in the house heres where the problems begin.
I cant run 6mm swa in the house as the route i have to run swa would just not be idle but in the garden swa would in a trench feed thou solvert weld pipe then gravel on top off that then warning tape and the back filled with top soil.
Can i run 6mm t&e from the house cu to the 6mm swa i been reading up that i would need a metal junction box for this ?
then can the swa go straight in the cu in the shed/workshop or would it have to be done back to t&e
wot cu for the workshop would be good would it have to be metal or can i use a insulated plastic cu
can the welder/ compressor have there own fuse in the cu same with the heater
i have been told i can use the electric cooker fuse in cu in the house as it not used is that true if so how would it be possible to do so
am sorry about all the questions i hope u don't mind me asking
i done quite abit off electrical work before which have all pass when tested
i want to do all the labour work myself then get sparky to connect it to the house cu
