I've just moved house, been in less than a month, since moving a radiator i've been having severe problems with my system.
After refilling and removing air, I found only the upstairs rads get hot, then suddenly the boiler wouldn't fire at all when CH was programmed to be on (hot water worked fine).
I found that the room stat had stopped clicking when turned so decided to replace, now boiler fires up fine when programmed for central heating as long as stat is turned high enough,
but also fires up when not programmed to be on at all! room stat will overide anything.
I can't say for sure if this is how it was before, when the old stat was working.
My system is ;
Glowworm space saver. 3 port honeywell valve. (new)
Honeywell room-stat (replaced like for like)
Whats worse is I still can't get heating to work properly and theres only 6 rads,
and return temps aren't good on any of the rads I can get warm or from hot water cylinder.
Could this mean the pump has now died, how can I check this?
help me
My system is ;
help me
