You may not believe this
Manuel Nubel's engine and prop was mounted in the fuselage. If you look closely at the video using stop action you will see the 'slot' about mid cockpit / wing .. Hence kissing the floor and wall performed without detriment.
...3D flight
3D flight is a type of flying in which model aircraft have a thrust-to-weight ratio of more than 1:1 (typically 1.5:1 or more), large control surfaces with extreme throws, and relatively low wing loadings.
These elements allow for spectacular aerobatics such as hovering, 'harriers', torque rolling, blenders, rolling circles, and more, maneuvers that are performed below the stall speed of the model. The type of flying could be referred to as 'on the prop' as opposed to 'on the wing', which would describe more conventional flight patterns that make more use of the lifting surfaces of the plane.
3D has created a huge market for electric indoor 'profile' types similar to the Ikarus 'Shockflyers' designed to be able to fly inside a gym or outside in little wind. These generally make use of small brushless motors (often outrunners, but also geared inrunners) and lithium polymer batteries. There are also many larger 3D designs designed for two and four stroke glow engines, two stroke gas engines and large electric power systems...
:shock:
JohnD said:
where's the prop?
i am wondering if its internal with airflow pushing and pulling down a hollow core !!!!!
the prop needs to change direction very quickly as the plane flies both back and forth and changes direction rapidly!!!
In a slot Ally boy ... in a slot mid cockpit / wing.
Rough but you'll see what I mean.
:wink:
More :
See the left hand, upper image, slot is open at cockpit ceiling.
In lower right hand image there appears to be a slotted guard vertically under the cockpit below the fuselage the whole thing is ultra lightweight but strong.
:wink:
I think that sort of flying is called 4D and uses VPP (varible pitch prop) the motor stays spinning in the same direction but the pitch of the prop changes (just like real planes and helicopters). Have a look at this video, that guys got skill.
http://rc.andersh.com/html/videofile.php?VidUID=1314
P.S. i fly electric model planes, but no where as good as those guys.
Yes the new lipo batteries and brushless motors make electric flying better than gas in my view. Great fun but one second of madness can lead to expensive pain!!
