We recently upgraded a gravity hot water system to fully pumped with an ACL Y plan pack but also using a Honeywell mid position valve ( dont know why - when I had got there one of the lads had decided to mix and match the packs - not that it should matter which valve is used ) - What we can't figure out is that now with the standard twin channel programmer the heating wont come on until the hot water is switched on ? Now they should work independantly and when using the ACL mid position valve in the past we get independant control so what difference would having a Honeywell valve make ? We had the sparky check all the wiring and he thought maybe a faulty programmer or head and as we had both on the vans we tried but to no avail ?
Any ideas ?
Cheers lads
Any ideas ?
Cheers lads
