Zanussi Electrolux ZWF12070w problem!
12 Jul 2011
Yorkshire
Hi
I put the cycle on, the washer starts filling up (very slowly) and then the start button starts flashing RED :(
The washer empties fine, I can set it to spin/drain and rinse and seem OK, only seems to happen when I want to do a wash??
I have tried resetting the ECO by filling the washer through the draw with water and draining, but didn't solve anything.
Please any help would be much appreciated.
Thank you :D
Posting the PNC helps us to help you as it is what identifies your particular model.
I take it it fills ok when you select rinse then and goes through the program and spins ok with a load.
Check the fill valves are operating properly at the top rear. Check the holes in the dispenser draw roof for blockages.
