I wonder if you can help??
I have an aprox 4 year old Zanussi WJD 1667 W washer dryer, which is not draining automatically.
I got my manual out, drained the water through the filter hatch, cleaned the filter (a bit clogged) checked the drain hose (all clear). It then finished its programme without any more problems(it even pumped/drained itself on the rinse cycle).
Solved I thought, just a bit of fluff in the filter.... err nope...
On the next wash it did the main wash, then came up with the E20 error (drain or filter problem) so I went though the same process and it carried on until it got part way through the rinse cycle - I started to drain it and the pump kicked into action.
Now each wash I'm having to drain it manually through the filter hatch, whereby when I empty it sufficiently, it carries on 'til it needs draining again.
Can you provide any guidance as to what I should try next ?
Do you know of any known faults with this model/range?
Regards
Jo
Regards
Jo
