Zanussi ZWX 1605W No power
6 Jul 2010
Middlesex
Hi all
Got a problem with the above machine went away for 5 days wife phones me up saying washing wont turn on
Just got back and have taken the top off to have a look and try and figure out what is going on.
The power on light lights up but a bit dim (can't remember if it was that dim before to be honest) no other button responds to anything though
Thanks in advance
Assuming you have checked the plug socket then their is a blue ribbon cable between the main circuit board and the display board you need to remove the fascia and check the connection going onto the display board as this furs up over time. If that's ok then one of the boards has failed and its more likely to be the main circuit board on the side.
Cheers i have taken out the main pcb on the side and had a look for burnt tracks after what ive been reading but all looks good.
One thing i'm not too sure on though is the Interference Suppressor i followed the mains in with a multimeter but couldn't get a reading coming out of this but assume it is working as the power light is on but dim.
Can someone confirm what i should be getting out of this please before i go and buy a new washer as if it is a board then i might as well get a new machine
Just double checked and have got power going frm it and out of the power switch
guess it's time to buy a new machine
