Hello,
We have a blockwood beech wortkop when it was installed it was oiled 3 times on all sides and cut surfaces with Danish oil.
I realise from the posts on here that
1. In for a dime, in for a dollar - we should've spent more and gone for granite
2. We should've used tung oil rather than Rustins Danish oil
It now has some minor damage including:
-Scratches
-"bleached" areas around the taps/sink
-Black Mould and very slight warping in one heavily used area.
This is of course due to my lack of maintenance, which I am now trying to sort out!
Questions:
1. Not all of the worktop has been damaged or the oil removed, do I need to strip the whole worktop to get an even finish or can I just strip the damaged areas then re-oil?
2. I would prefer to use Tung oil moving forward, does this mean that I will need to strip the full worktop, if it means less work I guess I will keep goign with the half a tin of Danish oil I have remaining.
3. To prepare the worktop for re-oiling I was going to use the following steps, can you please correct me if there is a better process:
- Wipe back area that requires re-oiling with white spirit
- Lightly sand with 120 Aluminium grit paper using sanding block by hand.
- treat areas affected with mould with oxallic acide to remove staining
- Sand progressively with 180, 240 grit paper.
- Apply liberally with soft cloth
- Wipe off excess after a few minutes
- Re-apply after 4-hours
- Repeat application another 2-3 times
- Expect to re-oil frequently, minimum every 6-months
I actually don't mind re-oiling often its just the surface preparation that I find a bit of a drag. Hence the key question of whether or not I should just follow this process with the whole worktop to ensure an even finish.
-Scratches
Questions:
