An MCB is a Miniature Circuit breaker. These normally have two parts, a thermal and a magnetic part. The thermal part causes the breaker to trip if it is slightly overloaded over a long period of time (i.e. it heats up, when it gets to a certain point it causes the breaker to trip). The magnetic part detects very large overloads, such as a live to earth fault.
An RCD is a Residual Current Device. This monitors the current going out on the live, and coming back on the neutral, and makes sure they're equal. If they differ by more than the rating of the device (commonly 30mA and 100mA ones), it trips. This will therefore detect a live to earth fault much more quickly, as it only requires 30/100mA to flow, unlike an MCB which will require enough current to trip the magnetic part to flow.
One thing to mention is that an RCD will not detect an overload, it only monitors for earth leakage. You can get RCBOs, which is a single breaker that combines an MCB and RCD.
so can the rcd also detect neutral to earth and live to neutral???
why does the enyclopedia say that it cant detect short circuits and you guys are saying it can detect live to earth faults?
Pobably because by short circuit it means live to neutral which is the one thing RCDs dont do (thats what the MCB or Fuse does).
