I know there are several posts on this but I don't feel I quite have the full answer for my situation so please bear with me. My terminology may be wrong so please excuse that also.
I have the Warmer Home people coming to lay 270mm of loft insulation on the 16th Dec. I want to board a section of the loft and to allow for the insulation I need to raise the height of the joists.
The diagram below shows a cross section of my roof space.
The blue section I believe to be known as the roof trusses and these are fixed to the front and rear outer walls of the house(?). All my first floor internal walls appear to be partition walls so I don't think there is any support to the ceiling. I can only assume therefore that the rest of the structure i.e the orange sections (name?) and the joists (brown hatched sections) are all 'hanging' from the trusses - is this correct?
The 2 small red rectangles are timbers that I originally thought ran from one side of the roof to the other but on emptying the loft I discovered they stop a few feet short of one wall - what are these for?
The part I want to board is the mid section of the diagram to cover the width of the house and I will be using the chipboard flooring packs from B&Q. This will be for storage only but probably to be accessed on a fairly regular basis.
My original plan was to fix 100mm x 50mm directly on top of the existing joists (which are 100mm x 30mm) using something like mending plates along one side (couldn't do other side as new timber will be wider and over hang) but with the apparent lack of support from internal walls I'm wondering if this is not a good idea.
Can I go ahead with this original plan or should I consider strengthening first and if so please advise how?
Many thanks for your patience on this subject that does seem to keep popping up!!!
