Earth bonding question
27 Aug 2003
London
Came across this neat looking product:
http://www.memonline.com/ezybondearth.html
Looks like it could save a professional sparky valuable time compared to wrestling with those wretched metal strap jobbies, which in my experience (and I'm actually not that clumsy) strip their threads 1 time in 3 or 4.
But I thought that earth connections had to be unbroken, i.e. the cable run is continuous, with sections of insulation removed where it visits a clamp rather than the cable cut?
I maybe wrong but my thought would be if it on the hot pipe would it become softer or bristle then undone or is it fireproof,would it then melt and would that cause problem compared to the metal fitting type?
Can we trust it not to come undone?
Be interesting to see what the others think.............
Oh I'm sure they'll have thought of that.
The website claims "Manufactured in heat and UV stabilised nylon 6.6 embodying excellent mechanical properties, chemical, heat resistance and self extinguishing characteristics."
Looks good.....I think it would only be good for end of line connections (ie, main equipotential bond to gas / water) wouldn't want to mess around when doing supplementary bonding in the bathroom....depends on cost aswell..is it worth the extra?
Why not?
Dunno what they cost, and anyway - only people for whom there is a time=money equation can make that determination.
xbonding needs to be continious, so this means cutting the insulation back with a knife (as you do anyhows) then threading the new earth clamp down the 6.0mm (like beads) to clamp onto the gas.......right or wrong.
and time is money, is it not?
sorry, clamp onto the water pipes in the bathroom (DOH)
Surely yes to gas pipes too, if you have them in the bathroom? (eg Ascot heater).
That's what I thought about the way you were supposed to wire - and it doesn't look as though that fancy clamp would slip over the insulation. Might be wrong.
Needs one of you pros to ask your supplier to ask MEM for some free samples - I'm sure they'd oblige.
i will phone our reps tomorrow and see if i can get a demo out
