Hi guys,
I seem to have a problem in a house I rent out. The overflow from the cold water storage tank is overflowing.
I checked the ball valve but this is functioning correctly, what I have noticed is that water is entering the tank from the vent pipe!
The hot water side of the CH system is not pumped, I think it works on gravity. The oiler is a Glow worm Hide away. I have played around with the boiler thermostat, the water is far too cold when at it's lowest setting or far too hot when turned fully up, so I suspect this is working fine. There is no stat on the cylinder.
I tried flushing the mains cold water throuh the vent to see if I had a blockage but had no luck with this.
One other thing I noticed is that the vent pipe does not climb very high above the water tank (maybe only 3 inches) before it drops.
Can anyone offer any advice in how to deal with this, it's only just started hapening after owning the house for over 2 years!
Thanks in advance,
Terry
Thanks in advance,
Terry
