Hi folks, I was wondering if anyone could help me on this one. The hot water basically doesn't get hot enough (i.e. when I run a bath the water is just luke warm) even if I adjust the HW temp setting to the highest setting (point 9) Just for info, the water does increase in temperature if I reduce the flow of hot water on the tap to less than half.
Is there something I can check. I've previously had to replace the thermistors, both primary temp sensor and DHW sensor and a new DHW switch so I'm reasonably happy undertaking the work. (p.s. don't worry, I used the white thermistors rather than the old blue ones which apparently are of poor quality)
Any help really appreciated, many thanks Ben
