Hi, can anyone help difuse a potential problem with our contracter/plumber?
As basically as possible we are renovating a fairly good sized house. The builders ripped out an existing 28mm gas main that ran 8 metrs through the property.
It supplied a 100btu CHB and tee'd off to feed a 5kw gas fire and an unknown load for a kitchen gas hob.
So, the plumber has relaid a 22mm main that now has to supply a 35/38kw boiler and the 5kw gas fire. The gas feed to the hob is no longer required, but there will be a take off a metre or so along the run for a 2nd gas fire.
Hope thats clear. Is the 22mm pipe good enough for this load????
Need to acy quickly before the whole lot gets boxed and plastered,
Cheers.
Cheers.
