My Ideal Isar boiler has started leaking. It’s leaking a drop at a time. I have opened up the boiler and taken a picture and marked the area where the water seems to be gathering and then dropping down. I can’t exactly see where the water is coming from.
CH pressure Has dropped since the leak.
Could this be because of frozen overflow pipe? Can anyone give some suggestions on what needs doing, to try to diagnose a bit further. If it looks like an expensive repair, I might as well use manufacturers one off fix option, otherwise I know a local Gas Safe guy.
