Which wood glue --- or no matter
27 Jan 2011
Midlands
I am about to lay 40m2 of eneineered oak floor 150mm wide planks 18mm thick I will be flaoting it. So what about glue choice - do I just go for screwfix no noncence or this http://www.toolstation.com/shop/p61864. Or perhaps evostick waterproof (the one in the blue bottle) Or does it not matter.
Also do I lay with the tounge to the wall and put the glue into the next boards grove Or lay with the groove to the wall and put the glue on to the tounge
any old pva should do, screwfix and such do an everbuild 1 litre or 5 litre tub which is pretty good stuff even though its quite cheap, and ive allways started with both grooves to the wall
hope this helps
tom
Thanks for that
So do you put glue to the top of the tongue of the board in your hand
2 small beads at 45 degrees along both sides at the top off the groove is my choice
other go for one hefty bead in the groove
others on the base off the tongue both sides
:D
everbuild here as well
when you say both sides do you meen lon and the short side of the board
2 beads mirror image in the groove about about 2mm from the top then you can run the nozzle along the corner without getting covered in glue
or onto the same position but on the tongue both sides
