Removing Olives
10 Dec 2008
Jersey Marine
I am going to change some 22mm compression fittings … is there an easy way of removing the old Olives off the pipe stub …. Would prefer to fit new ones, rather than reuse olive (and nut)
My usual approach is to have a set of gas pliers loosely around pipe up against Olive, and tap pliers with hammer to get Olive off.
I have seen some guy use gas pliers direct on olive … and really mess it up.
Any tips ?
Get an olive extractor yes, a bit expensive for a one-of job but life's too short to worry about botch-ups
Olive puller? (at a cost) but your method seems an easy way although I would try and cut the olive with a junior hacksaw as far as possible without touching the pipe
Junior hacksaw. If you can't get all the way through then make a groove and stick a flat blade screwdriver in and give it a twist, it should snap in half
If you are doing a few of them, I'd bite the bullet and buy the tool. Saves worrying/struggling with a hacksaw and you may need it again in the future.
Is this tool for pulling Olives off stub end of pipe .....? if so I assume it screws into the fitting 'nut' and act as a puler - pulling nut forward and dragging Olive with it. i.e. doesn't touch Olive directly.
It's probably not going to be needed for another few years (must be 10 yrs ago I last wanted to do this)
Junior hacksaw idea along with my gas pliers approach should suffice - thanks.
I wouldn't go anywhere near it with a hacksaw. Even the slightest nick will ensure that your new joint will leak. The only cure then is to cut the pipe right back and insert a piece. Mind you might find that the old olive has crushed the pipe anyway and a cut back back and will be needed.
Dickie Dyer olive cutters unlike most works on all size tube 15mm upwards.
Got one when I had a couple of days changing rad valves very quick to use zero damage to pipe.
More expensive than the puller and other threads have reported problems with it leaving marks on the tubing
