Boiler airlock
Are you getting hot water?
As suggested, the primaries (main flow and return pipes) to cylinder may need bled. Do you have 1 motorised valve or 2?
Yes there is hot water, it's taking its time to heat up as the boiler keeps cutting out after approx 5 mins.
This is my cylinder set up,don't know what motorised valves are sorry.
That blue box with MV22M is the motorised valve, above that is the manual air vent
So I opened it, a bit of air came out, should I do it when the boiler is running ?
I am not a plumber, but I would leave it open until water drips out before closing it.
  • Like
Reactions: CBW
Does it just twist off
So just unscrew that ?
Don't take it fully off, just until air expels and is replaced with water as per @opps. No do not do it with the boiler on. No, do not unscrew the motorised valve
Thanks, air did come out, boilers back on but can still hear the sloshing sound, will I have to do it a few times after the boiler has ran to get it all out.
  • Thanks
Reactions: CBW
Hi N,
My 80s system was poorly fitted, with only 1x pipe back to the loft tank, for filling and expelling air, plus few bleed valves, so I also get wind.
After spending ages getting the air out, after any radiator fitting etc, I solved it by using an adapted vehicle oil pulling pump connected to this pipe, while blocking the tank bottom water feed.
Hope this helps?
C
