EDIT - please don't be put off by the
s - the links work, it's just the thumbnails that ImageShack have managed to lose....
Comment/questions/suggestions...
Installing some outside lights - the cable will exit the house wall and go into an enclosure containing an RCD (house circuit is non-RCD) a couple of sockets, and B16/B6 MCBs for the sockets and the lights:
Fitting glands to trouser box:
First of two boxes being installed:
Closeup of a cable before the gland was assembled. When pushed together as the gland was tightened the armour did cover the cone:
Done. Before re-making when I found I'd not got long enough cores to get into the choc-block OK..
Grey sleeved blue used for neutral, black sleeved G/Y for cpc.
Closeup of 2nd box:
Choc-block was a bit of a squash in #1, so I used crimps in #2. As the cores are stranded I found that twisting 2 or 3 and then crimping gave excellent results - did a few test joints and tried very hard to pull them apart - wouldn't budge. When I open up #1 I'll see if the cables look stressed - I might replace the choc-block with crimps.
Photo of the internals for the enclosure:
Top right is the RCD/MCBs in a unit with a 16A socket.
Top left is a JB with a 4-core cable to run to the photo-switch - L/N/E/Switched Live.
The incoming supply will enter the mini-CU through the gland at the bottom, the outgoing cable for the lights will exit the JB through the gland in the bottom.
The G/Y cable from the Masterseal enclosure runs from the earth block in the CU to the earth stud of the main enclosure.
13A socket:
Mini CU w. 16A socket:
The cable supplying the MCBs is continuous - I stripped a section and bent it double to go into the yellow crimp. All the crimps are spades, they fit really well under the busbar screws of the RCD/MCBs.
Closeup of the JB:
CU & JB (a bit blurred, I'm afraid):
Photoswitch on the outside of the enclosure - the closeup got a bit too much flash, unfortunately:
Armour continuity connections:
All done, ready to fix to the wall and receive incoming/outgoing SWA cables:
Nothing is yet unchangeable, so if anybody spots anything horrific, let me know.
Once I've done the dead tests I'll be filling those trouser boxes with waterproofing compound.
Closeup of 2nd box:
13A socket:
Closeup of the JB:
