Would this be because they are not competent?
Possibly - I can see how DIYers could be competent to install to BS 7671, but not test.
Or how they could be competent, but not have test equipment.
Re- Read my post. I didn’t suggest that BS7671 defined competency; Only that it tells us we should Inspect & Test!
No, but your reply was in response to (partly) "
Where is the requirement that any test "must" be done only by a competent person?" - I was only pointing out that there's no definition of competence.
The address I offered as
the BR helpline address is an email address I was given in a reply to my emailing
[email protected], after reading an amended ODPM 2004 circular signed by Anne Hemmings. I had emailed with a Part P query. The reply I received although 4 weeks later, was very informative. They advised that if I had any further queries regarding the Building Regulations and in particular Part P, I should direct my queries to the address I posted! The circular is on the communities.gov.uk/planning website!
Bizarre.
I hope that a non-governmental commercial organisation is properly staffed to offer advice on legislative matters, and can be held accountable for any advice they give. And I hope you can see why I thought it odd that they should be touted as
the BR helpline..
Approved Document Part P as ammened April 2006! The Approved Documents give guidence on what the Building Regulations require in order for you to comply.
Let's try this again, and hope you don't regard it as a slagging match.
You said "Building regulations direct you to the BS7671 for direction.".
I asked you to show us where, and you then went on about Approved Document P.
Approved Document P is
NOT the Building Regulations, nor is it part of the Building Regulations.
So I'll ask you again - where do the
Building Regulations refer to BS 7671?
If you do not comply with the building regulations you are open to prosecution! What part of that do you not understand?
None of it.
What part of "The Building Regulations absolutely do not make the BS7671 requirements on testing part of the law" do
you not understand?
It clearly states on page 7, under General Guidance, Section 0, 0.1”In the secretary of state’s view, the requirements will be met by adherence to the “Fundamental Principals” for achieving safety given in BS7671:2001 Chapter 13. To achieve these requirements the installation must be… So on and so forth…. Away of satisfying the fundamental principals would be to follow… The technical rules followed in the body of BS7671:2001. as amended.” So on and so forth... In Fact, if you read it through you will see many references to BS7671 as amended.”
I'm aware of that.
What I'm not aware of, and what you have so far been unable to show, is where the
ACTUAL LAW makes complying with BS 7671 a requirement. Or where, apart from the definition of bathroom zones the
ACTUAL LAW even
refers to BS 7671.
Don't be silly. The On Site Guide is not a DIY hand book!
The Electrician's Guide to The Building Regulations is a useful companion.
In fact, the Electricians Guide you mention is probably a more practical book for the DIYer to understand. Why? Becuase this book explians in more detail what the Building Regulations are and offers guidence on how to interpret the On Site Guide!
Mattylad was talking about the regulations. I'm not denying the value of other guides, but the OSG is an IET publication, and the others are not
Ban-all-sheds, I could go on but I don’t want this to turn into a slagging match. Suffice to say, advising a DIYer to purchase a £65.00 book that requires years of learning to understand is not very good advise! In fact, to suggest that a DIYer is a (lesser Mortal) if they do not understand it is totally absurd!
I disagree that it's absurd, as it contains useful information, but I have never suggested that people make it their only source of information - I think it's one of the useful books they should consider.
What I wrote was in response to mattylad's observation about the cost, and I think it is reasonable to try and put £65 into perspective.
And to use your words "Re- Read my post" - it wasn't I that used the term "lesser mortals". If you don't like that then please take it up with the person who said it.
Even you should know that Fully Qualified Time Served Electricians who have been in the industry for many years have difficulty in interpreting many of the wiring regulations!
I can't be held responsible for other people's shortcomings.
