Er no, AFAIK speeding is also where you are guilty unless you can prove your inocence.
Don't be ridiculous. Without some kind of tamper-proof certified recording equipment in your vehicle you could never prove that. And there once was a case where a lorry driver was found guilty of speeding despite the fact that his tachograph showed he wasn't, and his tachograph was shown to be working and not tampered with.
If you are charged with speeding there has to be evidence that you were - they can't just
assert that you were and have you found guilty unless you can prove you weren't. (Ignoring the possibility that two policemen could collude and lie about what they witnessed from their patrol car, but if you are going to factor in police conspiracies and lies then all bets are off in everything....)
And here was I t'other day thinking nasty things about BAS because he was having a rant about something (I know not) & not I'm kinda warming to him... lol
I only rant about rantworthy things...
The whole thing appears to all be down to "interpretation" & how policy is defined by the LABC's so for any DIY'r who does not wish to pay oodles for a sparks to install & test and will do their own install, test etc then we are still going to do it outside of the regs because there is obviously no path that we can take otherwise.
Absolutely not true. There is no reason why a DIYer cannot follow the regulations in all respects, including testing.
DIY = Doing it Yourself so that you can save money.
And let's not forget the convenience of DIY, and the satisfaction.
Compliance = Paying lots of money & possibly getting the same job as DIY (possibly worse!).
You can DIY
and comply.
I have already said elsewhere that I am rewiring my 1850 house myself because of the state its in, just that I'd rather do it correctly/following the regs etc where DIY possible.
DIY is perfectly possible for the whole thing, but you do have to recognise that you require certain competencies, and you require certain specialised tools. But then you (probably) wouldn't try to rebuild your house from ground up with nothing but a typical DIY knowledge and a DIY toolkit at your disposal, would you...?
It seems that whatever route a DIYr takes to try and conform it is only one that will end up costing lots of dosh (and if we had that we might not be doing DIY in the first place).
Sadly the cost of notifying is often out of all proportion to the cost of the work. Maybe a complete rewire doesn't fall into that, but I bet you're not doing it in one fell swoop, are you....
FTR, Bro-in-law is a 17th ed electrician so I can at least get him to inspect & test it with me even if he cant sign it off.
If you get on with him, and you
really do know what you are doing, then he should be able to tell that. Speak nicely to him and see if you and he can work out a way where he is personally and professionally happy for you to work under his direction and supervision, and he certifies that he did the work.
This is not dodgy or bent
per se - it's the way that many companies operate, where they have qualified supervisors who can read without moving their lips and a herd of knuckle-draggers. (OK - I exaggerate for dramatic effect, but hopefully you see what I mean).
