Hi, I've recently renovated an apartment, and due to the style of the building, I opted to do away with the ceiling roses in the huge bedroom (it's a 1930's building and the original conduit wiring was disconnected years ago, and new wiring installed cheaply in plastic conduit on the surface of the concrete ceilings). Instead, I'm using floor lamps and task lighting which I prefer anyway, and instead of fitting in 2a round pin sockets (so I could switch them on from the lightwsitch, I decided to run a new 15a radial circuit from the cu to the lightswitch point in 2.5mm t&e, then to a couple of unswitched 13a sockets at suitable locations to accompany the 30a ring sockets. These are switched via a 20a dp grid switch to operate them from the door. Can anyone give me a reason why you don't see this setup usually? It seems like a much more sensible way of switching portable lamps e.t.c. without having to use 2a plugs?? (this is common in the US with 15a radial sockets operated from the lightswitch)
thanks
thanks
