So, the Heathrow crash landing then.
Has that subject stalled? Have its wheels come off? Has it run out of fuel? Or just ground to a halt?
I can assure you Noseall that the pilots certainly DO touch the controls and the engines are at full wet thrust ... It's not just the catapault that gets them airborne.Airplanes are steam catapulted off a ship, with the pilot NOT touching the controls
I have read about this in a few places and it is not accurate...And they land with engines at full throttle, so to be able to abort landing and gain altitude with immediate effect.
The answer is contained within your very next statement.blondini said:Where do you get the 'double-speed from' Softus?
Therefore, at take-off velocity on a conveyor, the wheels will be going twice as quickly as without a conveyor.You said:In the hypohetical OP there is no limit placed on the speed that the conveyor can achieve as it is simply stated that it will be able to match the wheelspeed of the aircraft.
Only if your theory allows you to ignore such practicalities as the inability of wheel bearings to rotate at infinite speed.blondini said:it is theoretically possible for the rolling resistance to increase to a point where it achieves equilibrium with the engine thrust which does have a limit.
All the footage of fighter pilots taking off aboard ship show them clearly and deliberately taking their hands off the controls at the point of take off.
in fact they have to show the deck controller their hands to be allowed to take off, and this is visible through the cockpit glass. they should NOT be on the controls.
this is so that the computer has control at the point or take off.
the pilot has control AFTER this point.
This is the signal to the shooter that they are ready to roll and was brought in following a number of incidents in the early days where jets were launched before the pilot was ready. The instinctive reaction is to pull back on the stick which can result in the catapault disengaging ... And the jet going over the side.all the footage of fighter pilots taking off aboard ship show them clearly and deliberately taking their hands off the controls at the point of take off.
Yes, but for the reason I have described above, not because the computer is taking control of the aircraft.In fact they have to show the deck controller their hands to be allowed to take off, and this is visible through the cockpit glass. they should NOT be on the controls.
Absolutely 100% notThis is so that the computer has control at the point or take off.
The pilot is in control ALL the time they are simply trained to resist the temptation to pull back on the stick until they reach the departure threshold ... Not because of computer controls or any such wizardry ... Simply so that they don't disengage the catapaultThe pilot has control AFTER this point.
Says who?With no limit on the wheel speed, it is theoretically possible for the rolling resistance to increase to a point where it achieves equilibrium with the engine thrust which does have a limit.
Marginally but it is by no means directly proportional as it is a factor of resistance to inertial movement (environment) and resistance of components (bearings etc) ... We can assume the former is static and that the dynamic component (the additional speed of the conveyor) is only dependant upon the latter which is negligable.If there is x amount of rolling resistance at a given wheel speed, is it reasonable to assume that as the wheel speed increases, the rolling resistance increases too?
I was going to draw and post a diagram to show how the inertial forces generated by the engine thrust are not relative to the ground but Softus has explained this better than I could have.
In this scenario there is no way that the rolling resistance on the wheel bearings could ever amount to the order of thrust produced by the aircraft's engine(s) ... Trents produce up to 74,000lbs ... or, in fact, anywhere close and I don't care how fast the wheels rotate.
There is a very real likelyhood that the bearings would seize, the heat packs would catch fire and the whole thing would crash and burn but that isn't the crux of the OP's question.
Practically or theoretically Blondini the aircraft's airborne.
MW
Give it up Blondini as you're talking boll***s
No. I can scarcely believe that you don't understand this.Are you confusing wheel speed with forward speed or air speed of the aircraft?The answer is contained within your very next statement.blondini said:Where do you get the 'double-speed from' Softus?
The wheel speed is directly proportional to the aircraft speed. If the aircraft doubles its speed, then the wheels double in speed.If the aircraft were travelling forward relative to a fixed point at a speed of 100mph and the conveyor was travelling backwards at the same speed, then yes the wheel speed would be 200mph. However the OP states that the conveyor will match the wheel speed of the aircraft, not the speed of the aircraft itself.
No - it's possible only in your imagination, which is not the same as being theoretically possible. However, a theory can be proven by showing the working, so if you have such a theory then please show the working.it is theoretically possible for the rolling resistance to increase to a point where it achieves equilibrium with the engine thrust which does have a limit.
I know that you don't know - this is why you've arrived at the wrong answer.Well we are already have to ignore the practicalities of the conveyor, but how fast the wheels would need to be turning to absorb enough energy to match the finite engine thrust, I don't know.Only if your theory allows you to ignore such practicalities as the inability of wheel bearings to rotate at infinite speed.
No it wouldn't - it would have to be twice as fast as normal. Whatever speed the plane is moving, if the conveyor matches either plane or wheel speed, then the wheels will be rotating twice as fast as they would if there were no conveyor there.It would have to be be extremely fast, but not necessarily infinite.
