baxi solo 3 not lighting, what is sequence of operation?
So the Overheat stat is ok, cause it currently reads 0 Ohms which is closed.
you shouldnt get 0 ohms, you should have a readable resistance which will be the same as when the 2 leads are together (test). there will be OL not 0 ohms mate - that means it is screwed. link it out for test purposes
I was trying not to be too technical here. I originally posted ~0Ω which is 'approximately' 0 taking into account lead resistance etc.
What do you mean by OL ?
OP can I have your email address? I have some information on this boiler you'll find extremly usefull.
Thanks very much for that , just what I was looking for.
Thanks for the help all.
Was confident enough about the anxillarys being ok to go ahead and buy a new PCB.
Fired up straight away.
