While the radiators water can be dirty and is not a health rish unless you drink it, it is used to carry heat that heats the cold water with the sardine stack acting as a separetor. Quite a common design. There are other ways to get the same result
Is yours the earlier design with three lights on the front or the later one with two lights?
You have hit on a design fault that occurs with the earlier models but the issue was addressed with the later ones.
It was cured by introducing a pump over-run after a hot water demand has ceased which dumps the primary hot water from the plate heat exchanger into the heating system.
PS I'm not normally this clever but I just got back from a Ravenheat training course.
