Hi all
I'm having a bit of a nightmare with the above mentioned fire. I'm not sure if I need a vent or not and if I do what size. The manual states I require 100cm 2 but the fire is only 3.5kwatt max, I believe I do not need a vent below 7kw.
If I require a vent what size hole do I need to drill, I have a 4" vent but that states on it 35cm2 which I assume would not be enough If I need to get 100cm2. Currently I need to vent some anger(sorry) and cannot install this loverly paper weight until I get this sorted.
Any help would be appreciated.
