CHAFFOTEUX ET MAURY. NO HOT WATER BUT HEATING IS FINE
9 Feb 2006
I HAVE A CELTIC 2.20FF RSC COMBI BOILER THE HEATING WORKS FINE BUT WHEN I TURN THE HOT TAP ON IT WORKS FOR A FEW SECOND BUT THEN IT JUST GOES COLD AND WHEN I CHECK THE BOILER THE PILOT LIGHT IS ON BUT ITS NOT FIRING UP
And I know what's causing the problem, but since you have such a low opinion of my diagnostic abilities I don't suppose you want to be told.
That's fine by me. I'm off to have a nice hot bath, goodnight :evil: .
Later edit - abusive posts by slider have been deleted by Mod.
Slider,
That aint very polite is it ?.
Chris did ask you nicely, come on matey.
Al
I bet around 50 htg engineers read this post but none will reply chris is a regular poster with some damn good advice so i expect you won't get an answer & yes i know what is wrong the part is about a fiver
Ignore those nasty people slider; I know what it is too - and will send you instructions on fitting it yourself, free, if you buy the part from me.
£150.
I DIDNT HAVE TO SPEND A PENNY WORKS FINE NOW SO KEEP YOUR PARTS TYPICAL CON-MEN. :evil: :evil: :evil: :evil:
On some boilers they have a water pressure switch that has a rubber diaphram in the unit. I will bet you pound to a penny it is either gone brittle or split. Hence the reason it may work sometimes but not always.
