My mother uses the safe zone for pinning up xmas decorations, what can you do?![]()
make sure her insurance and will are upto date and in a safe place?
Yes, but read whats written in 522.6.6(v) and not advice from any contractors club. The only safe way for a cable to enter or exit an expanse of wall is via the corner zones or the top of wall zones.
(v) be installed in a zone within 150 mm from the top of the wall or partition or within 150 mm of an angle formed by two adjoining walls or partitions. Where the cable is connected to a point, accessory or switchgear on any surface of the wall or partition, the cable may be installed in a zone either horizontally or vertically, to the point, accessory or switchgear.There is no such zone, the only zones are vertically upwards or horizontal.
So if the corner zone doesn't stop at the skirting, why does a vertical accessory one?Having had second thoughts, no it does'nt, so when coming from below (behind a skirting) the cable must be within 150mm of the corner of the room.
The regulation says that the cable may be installed in a zone either horizontally or vertically, to the point, accessory or switchgear.I have fully explained what the reg says, take it or leave it.
Since the regulation says that a cable may be installed in a zone either horizontally or vertically, to the point, accessory or switchgear, then if that point, accessory or switchgear is above a piece of skirting board then a cable may properly be run behind the skirting board.Cables can only go behind the skirting within 150mm of the room corner.
I mean that if you accept that a vertical zone in the 150mm of a room corner does not stop when it reaches the skirting board why do you think that the vertical zone from an accessory stops when it reaches the skirting board?No idea what you're talking about.
A way to have skirting board with cables running horizontally behind it.
Probably not.ah very good, I suppose that I'm th only one that took them on face value as a pointless post rather than a secretly hidden set of hyperlinks with no written explanation then..
I couldn't find stainless steeland I must ask, why aluminium?
Earthing it.what's the pop rivets for and what are the crimpers, ring crimp and single earth wire for?
Not sure I agree with that. What about dado trunking, if you don't happen to put any accessories in it?the skirting over the top makes it a partition..
It would stop them at least as well as the armour wires in SWA, and a damn sight better than the foil in BS 8436 cable.1mm steel is not sufficient to stop nails,
If the cable was at least 50mm from the top edge of the skirting, and the wall was at least 50mm thick then it would not. It would be positioned in the path of any nail or screw etc approaching from the <50mm direction.and otherwise it needs surounding with earthed metal, not just over the top of it..
I do know the rules, and I believe that an earthed steel plate would be at least as safe as SWA or BS 8436 or MICC and would therefore be permissible as per 120.3.you know the rules BAS, you quote them often enough..
I would have preferred plain non-animated numbers. Got bored looking.you had a few tonight BAS? you don't normally condone the use of lots of smileys in posts..
