Hi
Have old Netaheat Mk2F
Corgi engineer did service and I discussed fault with him. Boiler over-heating and sometimes cuts out with fan going but no pilot. Chugs along on min boiler temp. setting OK. Some improvement with new pump and cleaning system with chemicals. Blowing down pressure sensor tube causes it to fire up again when cut out. So either pressure switch or fan? As case gets v hot is it likely to be the fan more than the switch? Both seem very accessible and correct part obtainable plus replacement instructions from partsarena seem clear.
Is it reasonable for a DIYer to replace the fan and/or the switch as not directly gas-related? Switch would cost £150 to replace with Corgi bloke, £35 with me and same with fan but I don't want to wind up dead!
Some advice appreciated.
