tim west said:
...you can connect a low resistance to a votage potential but no current will flow unless there is some form of return path or a circuit.
That's a contradiction in terms - if you have a potential difference between two points then
by definition those two points are part of the same circuit.
If you doubt the accuracy of the words then consider the following scenario that I've based on your words:
1. Connect a single conductor to one pole of a SP switch, and bare the end.
2. Connect another conductor to the other pole, and the other end of that to your MET.
3. Remove the cover from your CCU.
4. Open the SP switch.
5. Measure the PD between the CCU live incomer and the bare-ended conductor. This should be zero volts.
6. Wearing rubber-soled shoes, and standing on a rubber mat, and holding the end of the bare-ended conductor, grasp the CCU live incomer terminal.
7. Since you're still alive and unscathed, let go of the CCU terminal. Wipe the sweat of your temples, and change your underpants.
8. Close the SP switch, and repeat step 5. This measurement should now be circa 240 volts.
9. Tell your wife where to find your will, and prepare to repeat step 6.
