The shaver socket currently installed is permanently live, with no means to isolate it. I don't want to do this using the light switch, as it's useful (for razor charging / electric toothbrush) to keep it live when the light is off. However, i do think it needs to be running through an isolator.
While i'm doing the fan install, is it ok to run the shaver socket the other side of the same FCU? So light, fan and shaver can all be isolated through the one FCU?
